critical-resource
      Profile Config Commands
Enables monitoring of resources
            critical to the health of the service platform, wireless controller,
            or access point managed network. These critical resources are
            identified by their configured IP addresses. When enabled, the
            system monitors these devices regularly and logs their status. Use
            this command to create a CRM (critical resource
               monitoring) policy.
A critical resource can be a gateway, AAA server, WAN interface, any hardware, or a service on which the stability of the network depends. Monitoring these resources is therefore essential. When enabled, this feature pings critical resources regularly to ascertain their status. If there is a connectivity issue, an event is generated stating a critical resource is unavailable. By default, there is no enabled critical resource policy and one needs to be created and implemented.
Critical resources can be monitored directly through the interfaces on which they are discovered. For example, a critical resource on the same subnet as an AP8132 access point can be monitored by its IP address. However, a critical resource located on a VLAN must continue to be monitored on that VLAN.
Critical resource monitoring can be enabled on service platforms, wireless controllers, and access points through their respective device profiles.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
- Service Platforms:
critical-resource [<CR-NAME>|monitor|retry-count]
         critical-resource <CR-NAME> [monitor|monitor-using-flows]
         critical-resource <CR-NAME> monitor [direct|via]
         critical-resource <CR-NAME> monitor direct [all|any] [<IP/HOST-ALIAS-NAME>|sync-adoptees] {<IP/HOST-ALIAS-NAME>|arp-only vlan [<1-4094>|<VLAN-ALIAS-NAME>] {<IP/HOST-ALIAS-NAME>|port [<LAYER2-IF-NAME>|ge <1-4>|port-channel <1-2>]}}
         critical-resource <CR-NAME> monitor via [<IP/HOST-ALIAS-NAME>|<LAYER3-INTERFACE-NAME>|pppoe1|vlan|wwan1]
         critical-resource <CR-NAME> monitor via [<IP/HOST-ALIAS-NAME>|<LAYER3-INTERFACE-NAME>|pppoe1|vlan <1-4094>|wwan1] [all|any] [<IP/HOST-ALIAS-NAME>|sync-adoptees] {<IP/HOST-ALIAS-NAME>|arp-only [vlan <1-4094>|<VLAN-ALIAS-NAME>] {<IP/HOST-ALIAS-NAME>|port [<LAYER2-IF-NAME>|ge <1-4>|port-channel <1-2>]}}
         critical-resource <CR-NAME> monitor-using-flows [all|any] [criteria|dhcp|dns|sync-adoptees]
         critical-resource <CR-NAME> monitor-using-flows [all|any] criteria [all|cluster-master|rf-domain-manager] (dhcp [vlan <1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>) {dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
         critical-resource <CR-NAME> monitor-using-flows [all|any] dhcp vlan <1-4094> {dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
         critical-resource <CR-NAME> monitor-using-flows [all|any] dns <IP/HOST-ALIAS-NAME> {dhcp [vlan <1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
         critical-resource <CR-NAME> monitor-using-flows [all|any] sync-adoptees criteria [all|cluster-master|rf-domain-manager] (dhcp [vlan <1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>) {dhcp [vlan <1-4094>| <VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
         critical-resource monitor interval <5-86400>
         critical-resource retry-count <0-10>
      Parameters
critical-resource <CR-NAME> monitor direct [all|any] [<IP/HOST-ALIAS-NAME>|sync-adoptees] {<IP/HOST-ALIAS-NAME>|arp-only [vlan <1-4094>|<VLAN-ALIAS-NAME>] {<IP/HOST-ALIAS-NAME>|port [<LAYER2-IF-NAME>|ge <1-4>|port-channel <1-2>]}}
                     | <CR-NAME> | Identifies the
                        critical resource to be monitored. Provide the name of the critical
                        resource. |
                     | monitor | Enables critical
                        resource(s) monitoring |
                     | direct [all|any]
                        [<IP/HOST-ALIAS-NAME>| sync-adoptees] | Monitors
                        critical resources using the default routing engine
                           all – Monitors all
                              resources that are going down (generates an event when all specified
                              critical resources are unreachable)any – Monitors any
                              resource that is going down (generates an event when any one of the
                              specified critical resource is unreachable)
                                 <IP/HOST-ALIAS-NAME> – Configures the IP address of the
                                    critical resource being monitored (for example, the DHCP or DNS
                                    server). Specify the IP address in the A.B.C.D format. You can
                                    use a host-alias to identify the critical resource. If using a
                                    host-alias, ensure that the host-alias is existing and
                                    configured.sync-adoptees –
                                    Syncs adopted access points with the controller. In the
                                    stand-alone AP scenario, where the CRM policy is running on the
                                    AP, the AP is directly intimated in case a critical resource
                                    goes down. On the other hand, when an AP is adopted to a
                                    controller (running the CRM policy), it is essential to enable
                                    the sync-adoptees option in order to sync the AP with the
                                    controller regarding the latest CRM status. |
                     | arp-only vlan
                        [<1-4094>|<VLAN-ALIAS-NAME>] {<IP/HOST-ALIAS-NAME>| port
                        [<LAYER2-IFNAME>|ge| port-channel]} | The following
                        keywords are common to the ‘all‘ and ‘any‘ parameters:
                           arp-only vlan
                              <1-4094> – Optional. Uses ARP to determine if the IP address is
                              reachable (use this option to monitor resources that do not have IP
                              addresses). ARP is used to resolve hardware addresses when only the
                              network layer address is known.
                                 vlan
                                    [<1-4094>|<VLAN-ALIAS-NAME>] – Specifies the VLAN ID
                                    on which to send the probing ARP requests. Specify the VLAN ID
                                    from 1 - 4094. Alternately, use a vlan-alias to identify the
                                    VLAN. If using a vlan-alias, ensure that the alias is existing
                                    and configured.
                                       <IP/HOST-ALIAS-NAME> – Optional. Limits ARP to a
                                          device specified by the <IP> parameter. You can use
                                          a host-alias to specify the IP address. If using a
                                          configured.port
                                          [<LAYER2-IF-NAME>|ge|port-channel] – Optional.
                                          Limits ARP to a specified port |
critical-resource <CRM-POLICY-NAME> monitor via [<IP/HOST-ALIAS-NAME>|<LAYER3-INTERFACE-NAME>|pppoe1|vlan <1-4094>|wwan1] [all|any] [<IP/HOST-ALIAS-NAME>|sync-adoptees] {<IP/HOST-ALIAS-NAME>|arp-only vlan [<1-4094>|<VLAN-ALIAS-NAME>] {<IP>|port [<LAYER2-IFNAME>|ge|port-channel]}}
                        resource. |
                     | via | Specifies the
                        interface or next-hop via which the ICMP pings should be sent. Configures the interface or
                           next-hop via which ICMP pings are sent. This does not apply to IP
                           addresses configured for arp-only. For interfaces which learn the
                           default-gateway dynamically (like DHCP clients and PPP interfaces), use
                           an interface name for VIA, or use an IP address. |
                     | <IP/HOST-ALIAS-NAME> | Specify the IP
                        address of the next-hop via which the critical resource(s) are monitored.
                        Configures up to four IP addresses for monitoring. All the four IP addresses
                        constitute critical resources. You can use a host-alias to specify the IP
                        address. If using a host-alias, ensure that the host-alias is existing and
                        configured. |
                     | <LAYER3-INTERFACE-NAME> | Specify the
                        layer 3 Interface name (router interface) |
                     | pppoe1 | Specifies PPP
                        over Ethernet interface |
                     | vlan
                        [<1-4094>|<VLAN-ALIAS-NAME>] | Specifies the
                        wireless controller or service platform‘s VLAN interface. Specify VLAN ID
                        from 1 - 4094. Alternately, use a vlan-alias to identify the VLAN. If using
                        a vlan-alias, ensure that the alias is existing and configured. |
                     | wwan1 | Specifies
                        Wireless WAN interface |
                     | [all|any]
                           all – Monitors all
                              critical resource IP addresses are unreachable)any – Monitors any
                              specified critical resource IP address is unreachable)
                                    use a host-alias to specify the IP address. If using a
                     | arp-only vlan
                           arp-only vlan
                              network layer address is known.vlan
                              [<1-4094>|<VLAN-ALIAS-NAME>] – Specifies the VLAN ID to
                              send the probing ARP requests. Specify the VLAN ID from 1 - 4094.
                              Alternately, use a vlan-alias to identify the VLAN. If using a
                                 <IP‘HOST-ALIAS-NAME> – Optional. Limits ARP to a device
                                    specified by the <IP> parameter. You can use a host-alias
                                    to specify the IP address. If using a host-alias, ensure that
                                    the host-alias is existing and configured.port
                                    [<LAYER2-IF-NAME>|ge|port-channel] – Optional. Limits ARP
critical-resource <CRM-POLICY-NAME> monitor-using-flows [all|any] criteria [all|cluster-master|rf-domain-manager] (dhcp [vlan <1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>) {dhcp [vlan <1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
                        resource. |
                     | monitor-using-flows | Enables critical
                        resource(s) monitoring using message flows for DHCP or DNS (DHCP discover,
                        DHCP offer, etc.) instead of ICMP or ARP packets in order to reduce the
                        amount of traffic on the network. |
                     | [all|any] | Configures how
                        critical resource event messages are generated. Options include all and
                           any.
                           all – Monitors all
                              specified critical resource is unreachable) |
                     | criteria
                        [all|cluster-master| rf-domain-manager] | Configures the
                        resource that will monitor critical resources and update the rest of the
                        devices in a group. Options include all, rf-domain-manager, or
                           cluster-master.
                           all – Configures all
                              devices within a group (cluster or RF Domain) as the monitoring
                              resourcecluster-master –
                              Configures the cluster master as the monitoring resourcerf-domain-manager –
                              Configures the RF Domain manager as the monitoring resource |
                     | dhcp vlan
                        [<1-4094>| <VLAN-ALIAS-NAME>] | The following
                        parameters are recursive and common to the ‘all‘, ‘cluster-master‘, and
                        ‘rf-domain-manager‘ keywords:
                           dhcp – Configures DHCP as
                              the mode of monitoring critical resources. When configured, DHCP
                              message flows (DHCP Discover, DHCP Offer, etc.) are used instead of
                              ICMP or ARP packets to confirm critical resource availability.
                                 vlan
                                    [<1-4094>|<VLAN-ALIAS-NAME>] – Configures the VLAN
                                    on which the critical resource(s) is available. Specify the VLAN
                                    and configured. |
                     | dns
                        <IP/HOST-ALIAS-NAME> | The following
                           dns – Configures DNS as
                              the mode of monitoring critical resources. When configured, DNS
                              message flows are used instead of ICMP or ARP packets to confirm
                                 <IP/HOST-ALIAS-NAME> – Configures the IPv4 address or
                                    host alias of the critical resource. Specify the IPv4 address or
                                    host alias name (should be existing and configured). |
                     | {dhcp [vlan
                        <1-4094>| <VLAN-ALIAS-NAME>]| dns
                        <IP/HOST-ALIAS-NAME>} | The ‘dhcp‘ and
                        ‘dns‘ parameters are recursive and you can optionally configure multiple
                        VLANs and critical resource IPv4 addresses (or host alias names).
                           dhcp – Optional.
                              Configures DHCP as the mode of monitoring critical resources. When
                              configured, DHCP message flows (DHCP Discover, DHCP Offer, etc.) are
                              used instead of ICMP or ARP packets to confirm critical resource
                                 availability.
                                 vlan
                                    and configured.dns – Optional. Configures
                              DNS as the mode of monitoring critical resources. When configured, DNS
critical-resource <CRM-POLICY-NAME> monitor-using-flows [all|any] dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>] {dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
                        resource. |
                        resource(s) monitoring using message flows for DHCP or DNS (DHCP Discover,
                        DHCP Offer, etc.) instead of ICMP or ARP packets in order to reduce the
                           any.
                           all – Monitors all
                     | dhcp vlan
                        [<1-4094>| <VLAN-ALIAS-NAME>] | Configures DHCP
                        as the mode of monitoring critical resources. When configured, DHCP message
                        flows (DHCP Discover, DHCP Offer, etc.) are used instead of ICMP or ARP
                           vlan
                              [<1-4094>|<VLAN-ALIAS-NAME>] – Configures the VLAN on
                              which the critical resource(s) is available. Specify the VLAN from 1 -
                              4094. Alternately, use a vlan-alias to identify the VLAN. If using a
                     | {dhcp vlan
                        [<1-4094>| <VLAN-ALIAS-NAME>]| dns
                        <IP/HOST-ALIAS-NAME>} | The following
                        parameters are recursive and optional. Use them to configure multiple VLANs
                        and critical resource IPv4 addresses (or host alias names):
                           dhcp – Optional.
                                 availability.
                                 vlan
critical-resource <CRM-POLICY-NAME> monitor-using-flows [all|any] dns <IP/HOST-ALIAS-NAME> {dhcp vlan [<1-4094><VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
                        resource. |
                           any.
                           all – Monitors all
                     | dns
                        <IP/HOST-ALIAS-NAME> | Configures DNS
                        as the mode of monitoring critical resources. When configured, DNS message
                        flows are used instead of ICMP or ARP packets to confirm critical resource
                           availability.
                              – Configures the IPv4 address or host alias of the critical resource.
                              Specify the IPv4 address or host alias name (should be existing and
                              configured). |
                     | {dhcp vlan
                        [<1-4094>| <VLAN-ALIAS-NAME>| dns
                           dhcp – Optional.
                                 availability.
                                 vlan
critical-resource <CRM-POLICY-NAME> monitor-using-flows [all|any] sync-adoptees criteria [all|cluster-master|rf-domain-manager] (dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>) {dhcp vlan [<1-4094>|<VLAN-ALIAS-NAME>]|dns <IP/HOST-ALIAS-NAME>}
                        resource. |
                           any.
                           all – Monitors all
                     | syn-adoptees | Syncs adopted
                        access points with the controller. In the stand-alone AP scenario, where the
                        CRM policy is running on the AP, the AP is directly intimated in case a
                        critical resource goes down. On the other hand, when an AP is adopted to a
                        controller (running the CRM policy), it is essential to enable the
                        sync-adoptees option in order to sync the AP with the controller regarding
                     | criteria
                           cluster-master.
                     | dhcp vlan
                                 vlan
                                    and configured. |
                     | dns
                     | {dhcp vlan
                        {<1-4094>| <VLAN-ALIAS-NAME>]| dns
                           dhcp – Optional.
                                 availability.
                                 vlan
                     | monitor interval
                        <5-86400> | Configures the
                        critical resource monitoring frequency. This is the interval between two
                        successive pings to the critical resource being monitored.
                           <5-86400> –
                              Specifies the frequency in seconds. Specify the time from 5 - 86400
                              seconds. The default is 30 seconds. |
                     | retry-count
                        <0-10> | Configures the maximum number of failed attempts allowed to connect to a critical resource, using DHCP/DNS message flows, before marking it as down
                           <0-10> – Specifies the maximum number of retries from 0 - 10. The default value is 3 attempts. |
NOC-NX9500(config-profile-testNX9000)#critical-resource test monitor direct any 19.234.160.5 arp-only vlan 1
NOC-NX9500(config-profile-testNX9000)#show context include-factory | include cri
tical-resource
 critical-resource monitor interval 30
 service critical-resource port-mode-source-ip 0.0.0.0
 critical-resource retry-count 3
